batt light on at 3000 revs +
Old Nov 10, 2007 | 08:21 AM
mooneys500's Avatar
Default batt light on at 3000 revs +
hi, i've a 96 S500. when engine revs reach 3500 and up the batt light starts to come on. goes out when revs drop back. Any ideas. if it is the alternator can brushes and reg be easily got and fitted. thanks.....
Old Nov 16, 2007 | 07:36 AM
syedabdulshahid's Avatar
Default RE: batt light on at 3000 revs +
It could be anything....
The driving belt is not loose
The rectifier is bad ( Burnt rotating diode/s)
The alternator brushes are worn out/ alternator has bad bearing/s.
A loose connection b/w the battery and the alternator
It is advisable to get the problem rectified beforeit becomes an
emergency and you will have to spend a lot.
Regards
Syed
kevin.beecher
Sep 15, 2011 02:55 PM
paddlingpool
May 24, 2011 01:55 PM
IKE
Jan 17, 2009 07:19 AM
MTSL550
Jan 4, 2009 04:15 PM
sa10
Jan 12, 2007 12:52 PM
