95 S420 Please advice! (cruize control actuator)
Old Oct 28, 2006 | 03:48 PM
Basafa's Avatar
Default 95 S420 Please advice! (cruize control actuator)
I own a 95 S420 for 7 years. About 2 years ago the car sat in the garage for about 5 weeks, when I tried to start the car, it would not start. I charged the battery, the car started but ran rough. When I stopped the car it would not restart. If it sits for a while ( 30 min ), it will restart normal. Surprisingly the check engine light is not on. I took the car to an independent shop they scoped the car and it showed problems with the cruise control actuator, but he was not sure that this was the problem. The car sat till last week. After purchasing a new battery I took the car to another shop. The mechanic tried to restart the car but it would backfired and failed to start. His diagnosis was that the throttle body actuator was bad and the distributor caps and rotors also should be changed. He suggested to also replace the camshaft position sensor. I checked with MBZ dealer and the throttle body actuator is also referred to as cruise control actuator or E-Gas actuator. I have read in the forums that there is a problem with wiring harness in these Mercedes models. How would I know if the problem is the Cruise Control Actuator or the Wiring Harness? Is there diagnostic tools that gives more information than others? Your suggestions and advice are most appreciated.
Thank you in advance, [sm=hail.gif]
MARIODRIVE
Nov 23, 2008 05:39 PM
Sandi
Sep 8, 2007 08:08 AM
aztntrunner
Jul 30, 2007 10:40 AM
alvarer
Sep 12, 2005 04:09 AM
