1993 400SEL - left signal lights stay on even when key removed
I have this strange problem the left turn signal lights staying on & will not flash.
This also manifests itself when the car is turned off & key removed from the ignition.
Has anybody heard of such a thing happening?
I have found that the instrument cluster fuse #17 will eliminate this but all the other lights inside are cut as well when the fuse is removed.
Also does anybody have a wiring schematic or diagram for this model & year?
Signed,
Desperately Seeking solutions
Signed,
hello,
turn your headlight switch to off position cause what you have done when you you tried to shut off your headlights with the switch you turned a little more to the left than it was supose to , so look at it and switch it clockwise direction just once.. and that should fix your problem, letus know how you make out..
[IMG]local://upfiles/26351/9116316E1FA844EDA49A426D33750563.jpg[/IMG]
ORIGINAL: benz_300se
hello,
hello,
I have owned this car for over 3 years now & am familiar with these different light modes.
This is a short or module problem of some sort.
you have to check the signal light turn switch, it may need servicing/cleaning, try playing with it by turning up down and see if there are any changes, and if you switch off the key and the light is still on, the wire going to that port has a problem and should be trace back starting from the fuse box back to the turn switch.
If only I had the same problem my turn signals wont work at all . Replaced the hazard Flasher switch made no difference looked for relay under console dont have one 1981 280 SE Could there be another relay somewhere . Checked fuses and bulbs all OK
KurskKnyaz
Mar 29, 2008 09:15 PM
jasperth
Aug 1, 2006 12:12 AM
