Too Many Engine Problems
Old Oct 4, 2021 | 10:05 PM
grkmspr's Avatar
Default Too Many Engine Problems
Hello,
i want to buy a used Mercedes ML350 4matic, but in my country cars conditions are not good, i found a mercedes ml with these error codes;
What i need to replace, car is a little bit shaking. it is worth too much or not?
Thank you
============1==============
P0016
Raw code: 0016
ECU: Motor kontrol ünitesi
Durum: Onaylı
OBDII: Crankshaft position/camshaft position, bank 1 sensor A - correlation
===========2==============
P0017
Raw code: 0017
Durum: Onaylı
OBDII: Crankshaft position/camshaft position, bank 1 sensor B - correlation
============3==============
P0300
Raw code: 0300
Durum: Onaylı
OBDII: Random/multiple cylinder(s) - misfire detected
Audi: Engine Misfire Detected
============4==============
P0301
Raw code: 0301
Durum: Onaylı
OBDII: Cylinder 1 - misfire detected
Audi: Cylinder 1 Misfire Detected
============5==============
P0302
Raw code: 0302
Durum: Onaylı
OBDII: Cylinder 2 - misfire detected
Audi: Cylinder 2 Misfire Detected
============6==============
P0410
Raw code: 0410
Durum: Onaylı
OBDII: Secondary air injection (AIR) system - malfunction
Audi: Secondary Air Injection (AIR) System
============7==============
P2015
Raw code: 2015
Durum: Onaylı
OBDII: Intake manifold air control actuator position sensor/switch, bank 1 - range/performance problem
============8==============
P2188
Raw code: 2188
Durum: Onaylı
OBDII: System too rich at idle, bank 1
============9==============
P2190
Raw code: 2190
Durum: Onaylı
OBDII: System too rich at idle, bank 2
============10==============
P2300
Raw code: 2300
Durum: Onaylı
OBDII: Ignition coil A, primary circuit - circuit low
skyhawk23
May 30, 2010 04:37 PM
Feb 6, 2009 01:05 PM
jimmy1938
Sep 19, 2007 06:38 PM
Nov 18, 2005 04:45 PM
Teddi
Sep 12, 2005 04:48 AM
