Too Many Engine Problems
Hello,
i want to buy a used Mercedes ML350 4matic, but in my country cars conditions are not good, i found a mercedes ml with these error codes; What i need to replace, car is a little bit shaking. it is worth too much or not? Thank you ============1============== P0016 Raw code: 0016 ECU: Motor kontrol ünitesi Durum: Onaylı OBDII: Crankshaft position/camshaft position, bank 1 sensor A - correlation ===========2============== P0017 Raw code: 0017 ECU: Motor kontrol ünitesi Durum: Onaylı OBDII: Crankshaft position/camshaft position, bank 1 sensor B - correlation ============3============== P0300 Raw code: 0300 ECU: Motor kontrol ünitesi Durum: Onaylı OBDII: Random/multiple cylinder(s) - misfire detected Audi: Engine Misfire Detected ============4============== P0301 Raw code: 0301 ECU: Motor kontrol ünitesi Durum: Onaylı OBDII: Cylinder 1 - misfire detected Audi: Cylinder 1 Misfire Detected ============5============== P0302 Raw code: 0302 ECU: Motor kontrol ünitesi Durum: Onaylı OBDII: Cylinder 2 - misfire detected Audi: Cylinder 2 Misfire Detected ============6============== P0410 Raw code: 0410 ECU: Motor kontrol ünitesi Durum: Onaylı OBDII: Secondary air injection (AIR) system - malfunction Audi: Secondary Air Injection (AIR) System ============7============== P2015 Raw code: 2015 ECU: Motor kontrol ünitesi Durum: Onaylı OBDII: Intake manifold air control actuator position sensor/switch, bank 1 - range/performance problem ============8============== P2188 Raw code: 2188 ECU: Motor kontrol ünitesi Durum: Onaylı OBDII: System too rich at idle, bank 1 ============9============== P2190 Raw code: 2190 ECU: Motor kontrol ünitesi Durum: Onaylı OBDII: System too rich at idle, bank 2 ============10============== P2300 Raw code: 2300 ECU: Motor kontrol ünitesi Durum: Onaylı OBDII: Ignition coil A, primary circuit - circuit low |
