new battery for ML320
Old Dec 21, 2007 | 12:22 PM
august240's Avatar
Default new battery for ML320
is there any special instructions to replace the battery of the 2001 ML 320? is it the same way with the other cars...just pullout the cables(-&+) and put the new battery?...
Old Jan 30, 2008 | 03:32 PM
limeyinusa's Avatar
Default RE: new battery for ML320
I'm assuming you've already done it but for the sake of future searches - yes.
I just changed my battery and it was pretty simple. It's a lot easier if you remove the metal bracket which allows you to move the metal sidewall to the side. I did need my wife to hold things a side whilst I dumped the really heavy battery in.
Pretty easy really though. Certainly better than forking out the money to the dealership.
Old Apr 18, 2008 | 06:40 AM
Celestialbar1's Avatar
Hi. I replaced the battery on my ML320 two months ago and had some few problems with the Immobilizer/Alarm system setting off as soon as I disconnected the old battery.
Usually on other cars it is possible to cut off the alarm with a special key. I found no other solution than replacing the battery with the alarm screaming in my ears.
Not only. I had to reset the traction control system by following the instructions in the manual and had to go to the MB dealer to re-sincronize the second keyfob, because the remote buttons didn't work anymore and the manual instrucions for this was not sufficient to settle the issue.
Sincerely I don't know if I would change the battery again alone, without knowing how to avoid all these problems!
Old Apr 20, 2008 | 12:46 PM
pscreech's Avatar
I used the MB OEM battery. Tried the Autozone one and it lasted 2 weeks. returned it and got my money back and immediately went to the dealer and got theirs. much, much better
95capriceclone
Sep 8, 2012 02:56 PM
akdjdk
Mar 3, 2010 08:57 PM
CL7X
Jan 19, 2010 03:41 AM
johnhong
Aug 31, 2009 07:38 PM
Jumpy07
Mercedes A Class
Mar 31, 2008 11:51 AM
