ML430 Interior Door Panels Fall Apart
Old May 26, 2009 | 10:39 AM
marshman 442's Avatar
Default ML430 Interior Door Panels Fall Apart
I have a 1999 ML430 and all of the interior door panels / plastic compartments have fallen apart and or have seperated from the door. When I open the doors they get hung up on the weather stripping and pull apart from the door. I would have to say this design sucks!
I was wondering if this is a common problem for the ML's and are there any special tools or tricks I should be aware of B4 I pull the door panels off. I plan on epoxying the plastic 'push-pins' to the back side of the door panel and then re-installing the door skin.
Has anyone had experience with this? Is it straight forward R&R? Will the power window wiring require and special attention prior to removal / special clips needed / special tools for removal / etc.
Please help.
Old Aug 30, 2023 | 09:50 AM
Eyezek's Avatar
Default How did that work out for you?
I'm having the same issues and was wondering how that "fix" worked out for you.
elundy10
Nov 22, 2009 02:15 PM
davnport
Jul 1, 2007 08:22 AM
zz4 gta
Aug 14, 2006 12:09 PM
RockSolid
Aug 23, 2005 01:38 AM
GrahamL
May 24, 2004 08:03 AM
