ML320 Coolant use and computer glitch...
Old Dec 18, 2006 | 09:37 PM
bossgobbler's Avatar
Default ML320 Coolant use and computer glitch...
I have a 2001 ML320 w/50k. It uses coolant but appeared to be leaking. I found one hose that needed tightning and that fixed one of the puddles. However when looking under the oil cap I found a yellow gooey substance indicating water and/or coolent mixing with the oil. Is there a moisure trap under the cap or is this an indication of a leaking head gasket or cracked engine block? It does not blow white smoke.
Also, recently the keys came out of sync with the doors. I followed the directions to fix this but they have failed. Now about four days later the parking lights are flashing every 5 minutes and the interior lights come on and the car unlocks. It is not possible to lock the car. Anyone with any ideas would be appreciated. Thanks.
Old Jul 8, 2007 | 06:48 AM
bigmalik00's Avatar
Default RE: ML320 Coolant use and computer glitch...
I need the same information. I have a 2002 ML320. I went to the dealership and they added some coolant (MB of course) When I drive my coolant level indicator comes on but later goes off. Is this a problem consistant with the ML? Do you have to use the MB coolant? thanks in advance.
SClassMatt
Apr 6, 2008 08:19 AM
byonkers
Oct 23, 2007 02:19 PM
Sclass4life
Jun 4, 2005 07:24 PM
rlteotico
8
Apr 2, 2005 01:20 AM
tim
Sep 14, 2004 12:32 AM
