ML270CDI remote key synchronized but not working
Since a few days I have a new (second hand
) ML270CDI (year 2000)
The remote key worked fine without any problems. Suddenly it refused to work.
Changed batteries, resynchronized but nothing helps.
I've synchronized the key and at the end (to complete the synchronizing) you close or open all or one door (when pussing the last button to finalizing the synchronizing).
But it is impossible to open or close afterwards with the remote key. I have to close with the central close button and close the driver door with the key to close my car.
Anyone an idea how to solve this problem?
Thanks in advance!
) ML270CDI (year 2000)The remote key worked fine without any problems. Suddenly it refused to work.
Thanks in advance!
Hi ARDK, did you sort your problem? just had the same issue with my slk and fixed it by...
insert key in ignition (don't turn) hold lock button down while still down remove key... Don't take your finger off lock button but with other finger press unlock 5-7 times.. put key back turn on to ignition.. the hazards will flash to confirm and remote works well... well it works for me.. good luck.
