LOW GEAR Not Working...???
Old Jun 22, 2006 | 04:09 PM
jorantes's Avatar
Default LOW GEAR Not Working...???
Ok I just purchased an '03 ML350, and followed the procedure in the owners manual to activate low gearing... when i press the button the LOW GEAR light flashes 4 times then does not stay lit... it also does not engage low gearing.... any ideas?
It also flashes 5 times when I start the car... Does the ML have a common problem that may explain whats wrong...? I am really limited with funds to fix this and would hate to pay $150+ just to have this diagnosed at the dealer...
What are all the possible things that could be wrong???
Old Jun 23, 2006 | 08:17 AM
roygrider's Avatar
Default RE: LOW GEAR Not Working...???
Make sure it is in neutral , and not rolling when you shift into low range. That is all I can think of.
Old Jun 23, 2006 | 12:20 PM
jorantes's Avatar
Its in neutral, flat pavement..... holding the brake pedal down, and then i touch the LOW GEAR button and it just flashes 5 times, but doesnt stay lit, or even engage... sound like the motor... any other ideas?
Old Jun 26, 2006 | 03:55 AM
vytamenc's Avatar
yes i have an idea have the codes read out.
Old Jun 26, 2006 | 04:34 AM
sleepwalker's Avatar
flashes 4 times?
it means that it recognise the command to shift, but the action is not completed.
it can be a problem on the actuator motor.
there is also a position sensor inside that actuator motor. if that sensor is faulty, you need to replace it with the motor.
patricknif
Mar 4, 2012 06:38 AM
Paul Dalton
Feb 7, 2012 02:37 PM
peetzc
Jan 27, 2008 11:53 PM
jazharp
Aug 19, 2006 03:08 AM
jazharp
Aug 19, 2006 03:06 AM
