Headlamp left/right drive adjustment
Old May 16, 2007 | 04:41 PM
wurkle's Avatar
Default Headlamp left/right drive adjustment
Going to take a 2005 M-Class to continent for couple of weeks and need to change headlight alignment as will be driving on 'wrong' side of road.
Dealer cannot advise how to do this without plugging in & running diagnostics to work out what headlamps are fitted (what?!?!).
Lamps are standard 2005 fit - halogens, clear outer lenses with round 'interior' lens. Dealer also suggested tape on clear part of lens (that would be the entire light then, suppose that would stop others being dazzled).
Surely this isn't that tricky?
Old Jul 26, 2007 | 05:30 AM
jbedford's Avatar
Default RE: Headlamp left/right drive adjustment
I'm looking for an answer to the same question for my ML500 (2002). Did oyu find a solution?
Old Aug 1, 2008 | 08:15 AM
donna's Avatar
Hello. Did either of you get an answer on this? I need to do the same for a 2001 C-class Estate. I guess the lamps are similar, if one doesn't have the Xenons.
I've just rung the dealer and they've told me that there is a metal "flip"-switch on the back of the headlamp - similar to those on BMWs if you're at all familiar. Will have to give it a go.
K5Chris
Jan 1, 2013 11:12 PM
jmcglynn
Dec 26, 2007 08:00 AM
pato_3plus
Aug 15, 2006 06:42 AM
loet
Aug 2, 2006 01:58 PM
jnash
Aug 23, 2005 02:58 AM
