fuel lines to filter 99ml
Old Sep 26, 2007 | 09:22 AM
briang's Avatar
Default fuel lines to filter 99ml
Hi, I was informed that you only need to replace the fuel line when replacing the fuel filter with the newer one on the 99 ml, but they sell 3 lines. The return, the fuel and one other. Do I purchase all 3 for about 100 bucks and the pliers for 59.00. with the filter I will have 235 dollars invested in this service. thank you[/align]
Old Mar 3, 2008 | 10:15 AM
vlowe's Avatar
Default RE: fuel lines to filter 99ml
When it came time to change my filter, I found that if you do not change all the lines you will wind up kinking at least one of them. This will restict or cut off the fuel flow - not good! Keep in mind this new style filter is longer and the 3 lines were re-designed to fit it. If you do not buy the MB tool, you can make one from a coat hanger - bend a "U" shape 3" long and at the ends of the "U", you need 2 right angle bends in order to depress the release levers.
racepak
Jun 19, 2010 04:00 AM
rmiley40
Nov 25, 2009 02:22 PM
F14tomcat5
Nov 10, 2008 11:13 AM
briang
Oct 1, 2007 08:06 AM
dmooney
Jul 17, 2007 04:43 PM
