Engine Scanner Connection...
Old Mar 24, 2008 | 12:01 PM
philevo's Avatar
Default Engine Scanner Connection...
I have a 1998 ML320 and the check engine light is on. I bought an OBDII engine scanner, where do I connect the scanner to the car? Where is the data access port?
Old Apr 2, 2008 | 09:27 PM
arambayzaee's Avatar
Default RE: Engine Scanner Connection...
Its near the engine release. Grab a flashlight and place your head down where your feet go...then look up, there should be a cover that is hinged and will allow you to insert the code reader.
Old May 27, 2008 | 10:05 AM
vlowe's Avatar
It's to the left of the steering column on the underside of the dash.
investoreducator
May 7, 2009 08:33 PM
boman49
May 9, 2007 02:53 PM
pc820
May 24, 2006 04:21 PM
investoreducator
Mar 20, 2006 06:39 PM
crit1
Nov 18, 2005 11:16 PM
