Brake light warning light on dash
Old Feb 13, 2010 | 10:58 AM
bluenose's Avatar
Default Brake light warning light on dash
Hi
need some help, I have had the brake pads replaced 200 miles ago, the problem I have is when I start the car the brake pad warning light comes on. It does not come on when braking only when starting the car or when the car has stopped and I keep my foot on the peddle
many thanks
Old Feb 13, 2010 | 04:09 PM
MB-TECH-38's Avatar
Default brake light on
bluenose,
did you recheck brake sensors
Old Feb 14, 2010 | 02:26 AM
bluenose's Avatar
Hi
thanks any ideas on what to check on the sensors
Old Feb 14, 2010 | 10:22 AM
MB-TECH-38's Avatar
bluenose,
see if for some reason brake sensor is touching rotor or if the sensor wire is broken and touching the rotor . when brake sensor wire touches rotor it goes to ground and completes the circuit so brake warning light comes on
Jerry
Old Feb 14, 2010 | 07:46 PM
gilgorm's Avatar
In case you didn't do this, you should have replaced the brake sensors at the same time the pads were replaced.
PelicanParts.com
Jul 25, 2013 12:22 PM
poormishi
Oct 20, 2007 08:02 PM
stevey88
Mar 18, 2007 05:19 PM
mrmemo
Mar 9, 2007 03:09 AM
white_190
Aug 3, 2006 03:59 PM
