Brake light warning light on dash
Hi
need some help, I have had the brake pads replaced 200 miles ago, the problem I have is when I start the car the brake pad warning light comes on. It does not come on when braking only when starting the car or when the car has stopped and I keep my foot on the peddle many thanks:confused: |
brake light on
bluenose,
did you recheck brake sensors |
Hi
thanks any ideas on what to check on the sensors |
bluenose,
see if for some reason brake sensor is touching rotor or if the sensor wire is broken and touching the rotor . when brake sensor wire touches rotor it goes to ground and completes the circuit so brake warning light comes on Jerry |
In case you didn't do this, you should have replaced the brake sensors at the same time the pads were replaced.
