Another fuel guage? diff fuse box
Old May 13, 2012 | 02:32 PM
ml3204life's Avatar
Red face Another fuel guage? diff fuse box
hello to all,I have a 1999 Mercedes ml 320 I have read several post in regards to trying to remove fuse #5 to re set the fuel system,now they say the fuse box is under the passenger side floor.That is only on newer models mine is located in the engine compartment so I looked for fuse #5 and it is not what the post is saying.so would it b a relay?Can someone tell me so I can be clear on what the fuse should say?or if it is a fuse or a relay?Thanks to all
Old May 13, 2012 | 02:40 PM
chassis221's Avatar
try passnegr side floor, the side kick panel under the dash. some fuses and relays there.
Old May 14, 2012 | 01:57 PM
ml3204life's Avatar
Really weird i removed the plastic shield uder the passenger side by ur feet the only thing i c is the blower motor and a few other thing but nothing that looks like fuses or a fuse box
Old May 14, 2012 | 07:14 PM
chassis221's Avatar
Side kick panel on the side not below the dashboard.. it's below the dashboard but on the right side.. it's on the floor.. you can see it has to screw driver type screws holding it in
Old May 19, 2012 | 07:00 PM
ml3204life's Avatar
Hello again,I see that the newer model has the fuse box in the car the 1998-2000 had all the fuses in the engine department now I read on another thread that another guy un hooked the power from the rear driver side to re set the float.Well I looked in the rear and seen 2 sep harness but not sure witch one is the one to un hook.Any help on what wire to un hook?Thanks to all
mike_olin
Aug 31, 2011 09:54 AM
tomfer114
Oct 19, 2010 07:26 AM
subseafb
Aug 13, 2007 06:50 PM
martino
Dec 19, 2006 09:17 PM
rr_havuz
Mar 11, 2004 07:55 AM
