ABS module repair problem..
Old Apr 26, 2023 | 01:36 AM
Deank61's Avatar
Default ABS module repair problem..
hi, I sourced a replacement ABS module, but was just going to swap the electric motor from the new one in , as it was a bushes failure ... but the little needle bearing came out of the housing where it drives the plungers. Has anyone got the bearing back in again without dissasembling the pump? ...its got me stumped...I can see maybe reverse pliers but they'd need to be custom made..
Old May 1, 2023 | 12:51 AM
Deank61's Avatar
made a little tool of sorts, sorted..
Old Jun 14, 2023 | 06:53 AM
Yong10mm's Avatar
Default Bearings
Try using heavy grease to stick them in place to fit the part in. I use that method with universal joints on trucks.
Old Jun 14, 2023 | 11:11 PM
Deank61's Avatar
thanks it was a bit tricky as there's plungers that come out into the bearing space that need holding back while the bearing is popped in..the bearing sort of floats between the plungers driven by an eccentric shaft from the motor...
Mcc23
May 10, 2022 07:49 AM
pcm84
Apr 27, 2012 03:44 AM
KOLAWOLE
Jul 21, 2011 08:01 AM
GaryK
Apr 26, 2007 12:16 PM
