2002 ML320 - won't crank when warmed up
Old Oct 12, 2013 | 05:51 AM
N4BBQ's Avatar
Default 2002 ML320 - won't crank when warmed up
When it's cold the car will crank and start with no problem. When the engine is warm (or just warm weather like it was here yesterday), then it will not crank.
I have searched various forums and came up with the CPS, but I don't know that if this is bad, it will stop the starter from engaging when it's bad. I only read that is won't allow the engine to start.
Ideas?
Old Oct 12, 2013 | 09:20 AM
chassis221's Avatar
the engine will still crank even if the crank sensor is faulty, it just wont start. you might have another issue. If the starter is not engaging then you could have a bad starter, or relay.
Old Oct 12, 2013 | 10:54 AM
N4BBQ's Avatar
Thanks. I verified this early this morning while the vehicle was cold by just pulling the cable from the CPS and trying to crank the engine. The starter engaged just fine.
So, I replaced the connector, cranked & started the car, drove it home (~8 miles) and it has cranked & started each time I've tried today. Crazy.
I'm going for a longer drive after the temperature rises a bit more today and see if I can duplicate the non-engaging starter again.
Old Oct 12, 2013 | 06:41 PM
N4BBQ's Avatar
Well I drove the vehicle numerous times today and have walked out into the yard and cranked and started it at least fifteen times and it fired up each time.
I just walked out to move it into the garage and now it won't crank again. Maybe it'll stay broken so I can take some measurements tomorrow and see what's going on. I'm hoping it's a dying starter/solenoid. It's too dark out now to mess with it.
concord
Jun 16, 2020 02:09 AM
diz 4matic
Nov 13, 2008 11:36 PM
vlindell
Oct 28, 2008 08:33 PM
imosh
Apr 10, 2008 10:12 PM
kringkast@mac.com
Sep 20, 2005 05:27 AM
