2002 ML320 P207E code
Old Apr 8, 2012 | 06:21 PM
TXN's Avatar
TXN
Default 2002 ML320 P207E code
My ML320 got Chk Eng light turned on. I did use a diagnostic scan tool to retrieve code and found code P207E (Catalic converter redement too low (P0432) in register. I reset code, and occasionally re-run the diag and found the same code re-appeared but this time there's no check engine light . It might be because the error threshold has not reached to turn on the light ? There's some discussion about oxygen sensor . Can I get some expert opinion on this error code please ? Thanks for the help
Old Apr 18, 2012 | 09:29 PM
alex_22289's Avatar
most of the time when there is a cat efficiency code, the problem is the cat. also some mls have had recalls on the cats. you should check to see if yours has a recall
Old Apr 21, 2012 | 05:32 PM
TXN's Avatar
TXN
Thanks Alex..
I replaced the downstream O2 sensor and haven't not seen the error for a week. Keep my fingers crossed
i617gem
Oct 3, 2011 04:57 PM
snakaishi
Mar 6, 2011 03:18 PM
rbjb99
Feb 8, 2011 01:06 AM
mbenz66
Apr 8, 2006 10:25 PM
mbenz66
Mar 18, 2006 11:41 PM
