Will 18" Monoblocks bolt up to a 97 E320?
I just checked Tirerack.com and they have an AMG Aero II monoblock rim for your 320 in 18 inch rims. The rims are 18"x8" with an ET 31. The recommended tire for these rims are 235/40-18. Tirerack also has an optional 18"x9" monoblock rim for the rear with an ET +35. The recommended tire size for the optional rear only rim is 265/35-18.
I use the specs at tirerack to give me an conservative idea about wheel and tire sizing. You can check wheels from other sources against these specs. The 17' rims will fit so check the reference if you decide to go with the smaller rims. There is also good thread discussing the pros and cons of 18 inch rims on earlier E-class models on this forum. It may not apply for your E320. Check it out.
Cheers, JDub
Cheers, JDub
Eric, I misinformed you about the thread on bigger wheels. Look in Automotive forums.com-> Mercedes Benz->E Class->Bigger Wheels. This thread has some comments on it that may be of interest. The subject car was a 99 4-matic.
Cheers, JDub
Cheers, JDub
kristine
Sep 9, 2006 09:17 PM
