transmission not shifting from 1st gear
Old 06-12-2008 | 09:07 PM
frk203's Avatar
Default transmission not shifting from 1st gear
i bought a used e420 with a transmission problem, the transmission will not shift out of 1st gear (or it might be 2nd gear as some people in other forum said that this is limp home mode)
the check engine light is one and with a regular scanner i got theses 2 codes (after i reset it and drove it):
1. P0105 (pending) Manifold Absolute Pressure/Barometric Pressure Circuit
2. P0730
Incorrect Gear Ratio
Old 06-12-2008 | 10:10 PM
ohlord's Avatar
Banned
Default RE: transmission not shifting from 1st gear
The pending map code may just clear itself,if a temp condition existed.
The gear code may need some checking into the connections to the trans and fluid level
what year 420?have you tried a reset?
ohlord
Old 06-13-2008 | 01:24 AM
snanceki's Avatar
Stock wheels and tires?
Stock air cleaner assembly?
Need more history.
Stuart
Old 06-13-2008 | 05:55 AM
frk203's Avatar
the car is 1997 with 125000 miles original rimes and same tire size as original transmission has been replaced with another usedtransmission that had been testedbut still have the same problem
Old 06-13-2008 | 05:59 AM
frk203's Avatar
sorry if my replies are short but for some reason the forum is not letting me post replies that are more then 1 line long
Old 06-20-2008 | 01:16 AM
frk203's Avatar
any help?
Old 06-20-2008 | 08:35 AM
ohlord's Avatar
Banned
Forget the pending.
Trans module needs to be checked.
Any good shop with the sds system will test it.
ohlord
Old 06-22-2008 | 05:45 AM
frk203's Avatar
transmission was leaking oil
its working fine now after i got the leak fixed and got the oil changed
gregp1962
11-04-2011 03:17 PM
laura51978
02-21-2009 08:15 AM
redrockmountain1000
08-22-2007 01:46 PM
tan190e
03-24-2007 01:09 PM
redly1
09-02-2005 08:01 PM
Quick Reply: transmission not shifting from 1st gear
