Transmission gear problem
Old Feb 17, 2006 | 01:27 PM
DinAMG's Avatar
Default Transmission gear problem
Hello everybody
I am new member in this forum, My name is Din from Manchester UK. I have transmision problem with my car E230 avangrade. When engine is cool especially at morning the gear take time to shift from the 1st gear to 2nd gear. Eventhough i warmming up the engine before i start my journey, it still happen. But some time it drag about 100meter then it will change to second gear but the other gear is no problem . Can anybody suggest what should i do to solve this problem?.
Thank you for spend your time to read this.
regards
din, manchester
Old Feb 17, 2006 | 10:50 PM
sleepwalker's Avatar
Default RE: Transmission gear problem
welcome.
it's warming up the catalyst.
does it behave the same before? or it's worst now?
Old Feb 23, 2006 | 05:23 PM
teddybear's Avatar
Do you live on a level road or at the bottom of a hill in Manchester? What mode is the gearbox in W/S or has it got S/E or C/S marked on the switch does this make a difference? Warming the engine up before driving off for 5 minutes will have little effect on the temperature of the transmission fluid. Its a hard thing to diagnose without driving the car I would check a few basics like the ATF level and check the condition of the fluid is it nice and pink or is it smelly and dark brown , speak to the last owner ? Is it all OK once its at normal working temperature ?
Old Feb 23, 2006 | 08:39 PM
Lugnut's Avatar
What he's describing is normal, just as sleepwalker said. It's a scheme M-B uses to fire up the cats sooner.
Old Feb 26, 2006 | 05:46 PM
vytamenc's Avatar
this is normal. it is preheating your cat.
Hus
Mar 10, 2008 12:50 PM
totx
Oct 25, 2007 06:01 PM
kmaule
Mar 7, 2006 08:06 AM
redly1
Sep 2, 2005 07:01 PM
SANDDOG
Apr 23, 2004 01:59 AM
