Transmission
I have a 2000 E430 with automatic transmission. Yesterday I was at a stoplight, and when I went to take off, the car started to roll back (yes the car was in gear, and I was on an incline) Lol. After turning the car off and restarting it, the car drove fine.
Later, as I left the house on my way to work, the car would not accelerate above 25 mph because it was stuck in first gear.
Now, the car will not go into gear at all. It feels as though the shifter is useless - usually I can feel the shifter putting the transmission in gear, now I don't feel that.
sounds like your linkage grommet, its cheap 5$ right under your lever and can be seen from under the car, it holds the other end of your shift lever to the control rod thats connected to your trans. oder it online and any mechanic or you can install it
Pelican Technical Article: Mercedes Benz - Gear Selector Bushing Replacement
roy@pelicanparts.com
IMO; It is cheaper to have the dealer diagnosis.
Here is a brief list of what may have failed causing your symptom.
Shift Lever Assembly
MB# 2102670524
dealer $560.00
pilot bushing
MB# 2035400253
dealer $14.50
control unit
MB# 0002701852
dealer $478.00
electronic-hydraulic control unit
MB# 1402700606
dealer $1230.00
Conductor Plate - Above Automatic Transmission Valve Body
MB# 1402701161
dealer $274.00
valve, x3
MB# 2402700289
dealer $55.00 each
valve, x2
MB# 2032700089
dealer $204.00 each
valve
MB# 1402770435
dealer $61.00
transmission control unit
MB# 10255452132
dealer $1190.00
