Transmission
I have a 2000 E430 with automatic transmission. Yesterday I was at a stoplight, and when I went to take off, the car started to roll back (yes the car was in gear, and I was on an incline) Lol. After turning the car off and restarting it, the car drove fine.
Later, as I left the house on my way to work, the car would not accelerate above 25 mph because it was stuck in first gear. Now, the car will not go into gear at all. It feels as though the shifter is useless - usually I can feel the shifter putting the transmission in gear, now I don't feel that. |
linkage grommet
sounds like your linkage grommet, its cheap 5$ right under your lever and can be seen from under the car, it holds the other end of your shift lever to the control rod thats connected to your trans. oder it online and any mechanic or you can install it
Hmm
Originally Posted by sun111
(Post 158918)
sounds like your linkage grommet, its cheap 5$ right under your lever and can be seen from under the car, it holds the other end of your shift lever to the control rod thats connected to your trans. order it online and any mechanic or you can install it
Pelican Technical Article: Mercedes Benz - Gear Selector Bushing Replacement roy@pelicanparts.com . |
Answer
Originally Posted by sandybenzo
(Post 158917)
Later, as I left the house on my way to work, the car would not accelerate above 25 mph because it was stuck in first gear. Now, the car will not go into gear at all. It feels as though the shifter is useless - usually I can feel the shifter putting the transmission in gear, now I don't feel that. IMO; It is cheaper to have the dealer diagnosis. Here is a brief list of what may have failed causing your symptom. Shift Lever Assembly MB# 2102670524 dealer $560.00 pilot bushing MB# 2035400253 dealer $14.50 control unit MB# 0002701852 dealer $478.00 electronic-hydraulic control unit MB# 1402700606 dealer $1230.00 Conductor Plate - Above Automatic Transmission Valve Body MB# 1402701161 dealer $274.00 valve, x3 MB# 2402700289 dealer $55.00 each valve, x2 MB# 2032700089 dealer $204.00 each valve MB# 1402770435 dealer $61.00 transmission control unit MB# 10255452132 dealer $1190.00 roy@pelicanparts.com . |
