Spark Plug Cables for 190E - diagram
Old 10-17-2008, 01:23 PM
sajohn's Avatar
Default RE: Spark Plug Cables for 190E - diagram
OK Looking at you diagram of the engine,
A= 1
B=2
C=3
D=4
Match thise with the numbers you show in Grey on the cap
  #12
Old 10-17-2008, 02:05 PM
m3rc3d3s's Avatar
Thanks for reply again!
Just in case, I attached a diagram.
Hope this is it.
[IMG]local://upfiles/35908/CB82C68A74014EB9A59B1244470C3956.jpg[/IMG]
  #13
Old 10-17-2008, 02:08 PM
sajohn's Avatar
That looks right!! It should do well.
  #14
Old 10-17-2008, 02:32 PM
m3rc3d3s's Avatar
Thanks again!
I am now recharging battery, it has to be full when I will start the engine again.
Will try after it will be recharged.
  #15
Old 10-18-2008, 05:40 AM
m3rc3d3s's Avatar
It works!
Motor started fine, strong. means - that problem is solved!
Then I stopped it.
After ten minutes I started it again - it works, butit's cold - then it started shaking, not much, but enoughto expect it would stop.
Should I consider to change air filter? Or is there anything that may help?
  #16
Old 10-18-2008, 09:37 AM
sajohn's Avatar
What are the RPM's when shaking? 500? Any dash lights?ie. SRS, ABS?
it couls be an engine temp sensor or a relay not sending the correct signal to the computer.
  #17
Old 10-18-2008, 09:42 AM
sajohn's Avatar
Yes change the air filter and the breather, also looking at the engine, at the 11 O'clock from the distributor you will see a sensor with 2 wires. pull the wires and clean the contacts. You may need to change that sensor. It is your engine temp sensor.
  #18
Old 10-18-2008, 05:46 PM
m3rc3d3s's Avatar
Unfortunately, I'll have to wait until monday - then I'll buy air filter.
Just to explain about the engine behaviour.
When I start engine, it starts immidiately, after few seconds (if it's cold) it starts shaking, then RPM goes down - from first 750min 900max to 0.
I have to take care that RPM is not going down - so I have to force it to 1200 - 1500.
When engine gets the working temperature, everything works fine.
Temperature sensor I replaced recently.
I have to say that the engine is usingboth gasoline and LPG. Everything seems to be the same with LPG.
It's "i" direct injection version engine.
Is there a possibility for the nozzles to be dirty, or the place below air filter,where air is entering and mixing with the gas to be dirty?Should I try to clean it with gasoline?
kzukowski
05-02-2011 09:44 PM
nieto1
04-12-2010 09:26 PM
nieto1
04-10-2010 06:22 PM
qha000
11-27-2005 01:21 PM
benztech75
08-30-2005 07:42 PM
Quick Reply: Spark Plug Cables for 190E - diagram
