Shocks and Springs Help
Hey i need help in purchasing new shocks and springs for my e320 '96....anyone have any suggestions what i should go with...i was looking for something to lower my car but not to much and also shocks that will preserve the normal benz ride....Help would be appreciated...Thank you!!
RE: Shocks and Springs Help
ORIGINAL: Creative85
thanks for the help...i found bilstein shocks..but can anyone explain to me the difference between sport shocks and heavy duty shocks...thank you!
and I would match Vogtland with Bilstein - closer to stock ride quality
if you head to Bilstein web site, you'll see that the HD is closest to MB ride, though 10% more compression and rebound dampening. The physical length is same as MB, ie for factory issued spring/ride height. With the SPORT shock, it is physically shorter than HD, and designed for use with many of the lowering springs which provide approx 1.25+ inch drop. The dampening is a little firmer than HD as well.
If you use the full length HD shock with lowering springs, immediately it robs the shock with that amount of travel right off the bat...approx 1.25-1.5". Upon full spring compression (high speed, dips in road, potholes, etc) it is possible to bottom out the shock given the now, much shorter available travel. The SPORT shock is designed to minimize this problem.
rocafel1a
09-06-2008 03:46 PM
DGW203
07-06-2006 12:19 AM
jpchleapas
01-14-2006 03:20 AM
