Radiator water mixed with engine oil--E250D
Old Jun 20, 2011 | 11:25 AM
knight's Avatar
Default Radiator water mixed with engine oil--E250D
I had just bought E250D, 1999 model .after 2 months she started giving starting problem.
when check found that fuild line was choked, and also saw that their was engine oil mixed with radiator water.Lot of people with differents solutions.
If any one is aware of real problem, then it will be great help.
Thx
Knight
Old Jun 22, 2011 | 09:33 AM
peter.I's Avatar
If you get coolant (radiator water) into the engine oil then the oil would turn into milky color (white). Do not run engine at all in that situation to avoid costly damage.
In my opinion the head cylinder gasket is shot and must be replaced.
Old Jun 23, 2011 | 07:35 AM
knight's Avatar
Thanx Peter,
The engine oil is very dark , and looks like proper oil with out any water .
One can see water and oil mixed in radiator water container only
The starting is perfect and running is also great. even temprature is normal. accerelation is also good with zero loss of power
somebody told me it could be bcoz of faulty oil cooler.
pls help
Can you please guide , what are the check points if head gasket is shot or damage
Thx
Old Jun 24, 2011 | 02:11 PM
peter.I's Avatar
Default oil in the radiator
In my opinion if the oil in the engine was not contaminated with coolant (milky color) and you said that oil was only in the coolant expand container then I wouldn't suspect the head cylinder gasket at all.
With the engine cooled off open the radiator cap and examine the coolant. If the coolant (water) has proper color (not milky color) then you might have had dirty expand container and it needs a cleaning job. After that I would drain the coolant, refill with fresh water and run the engine for an hour and re-examine the coolant.
Old Jun 24, 2011 | 08:40 PM
Rockerfella174's Avatar
Knight,
must be the oil cooler...I have that case a few times on ML's and S class Wdb 202 , do service your engine oil and radiator. replace new coolant due to contamination in your cooling system
everythingmercedes
Aug 21, 2008 04:44 PM
everythingmercedes
Jun 26, 2008 11:44 AM
activeirish
Dec 13, 2006 07:03 PM
Welsh Ad
May 16, 2006 10:06 AM
