Quick question
Old Sep 9, 2006 | 10:24 PM
grhmb's Avatar
Default Quick question
I need to replace the alternator on my 1989 300E I was wondering what i need to do in regards to the belt how do I loosen it or do I even need to. Can i find this on braingears? Thank you for any help
Old Sep 10, 2006 | 03:36 PM
jackd's Avatar
Default RE: Quick question
Are you sure you need to replace the alternator.
A charging problem????. You can buy the the voltage regulator and the brush set for about $30..
All you need is a simple screw driver and 10 minutes of your time.
This will solve 95% of all alternator problems.
Old Sep 12, 2006 | 01:13 PM
grhmb's Avatar
The car runs dut after a few feet power cuts out and it will not restart until jumped. The same thing occured with my mothers 300E and after the mechanic replaced the battery and alternator it has not happened since. What you are saying is should they just tried to clean and replace the brushes first? Thank you for your help.
Old Sep 19, 2006 | 11:30 PM
grhmb's Avatar
Thank you very much for the help replacing the voltage regulator did the trick and saved me a couple hundred. Your advice was much appreciated, It runs perfectly now.
EazyE
Dec 24, 2005 01:26 PM
fonyx
Dec 2, 2005 01:44 PM
WANTED_560SEC
Nov 10, 2005 10:39 PM
fay3131
Sep 18, 2005 04:44 AM
erfaniman
Apr 3, 2005 07:37 PM
