Power Locks
I am pretty sure that your power locks are vacuum related. I would check under the hood for any sort of vacuum leak. If it is not vacuum related, there should be a fuse for it in the fuse panel. Check your owner's manual, or Haynes manual if you have it, and try to locate the fuse/vacuum leak. Hope that helps.
Matz445
Oct 12, 2006 05:39 PM
