Oilchange gearbox ´98 300tdt
Old 08-09-2004 | 06:56 AM
toien's Avatar
Default Oilchange gearbox ´98 300tdt
Hi everyone.
Is it difficult to change oil in the automatic gearbox in a E 300 tdt´98? How much oil does it contain and how to "measure" it since there are no stick to do so. (Please have patience with my English, I´m from Sweden".
thanks
tobbe
Old 08-09-2004 | 10:23 AM
sleepwalker's Avatar
Default RE: Oilchange gearbox ´98 300tdt
if you will drain from the oil pan, 1 3/4 liter is enough but if you will drain the torque converter (there is a small hex screw), then about 3 liters.
the best way is to measure the oil that you drained and add about a cup.
without the chopstick, err... the dipstick, you have no way of knowing it.
Old 08-09-2004 | 11:29 AM
toien's Avatar
Thank´s a lot for the qiuck answer. What kind of oil should I use then, any ATF-oil or is it neccessary to use "Mercedes"-oil?
tobbe
Old 08-09-2004 | 09:39 PM
ATF oil.
the viscosity are all the same.
using MB ATF is good, so you can prevent any shifting problem.
i use the same oil on that little green man on the left, and he keeps on running for long now.
chadwenger
06-21-2007 11:16 PM
chrisspaulding
12-14-2006 11:42 AM
ergoa
06-30-2006 04:12 PM
peaceandloveforus
06-30-2006 02:37 AM
tsiero
04-19-2006 11:22 PM
Quick Reply: Oilchange gearbox ´98 300tdt
