Oilchange gearbox ´98 300tdt
Hi everyone.
Is it difficult to change oil in the automatic gearbox in a E 300 tdt´98? How much oil does it contain and how to "measure" it since there are no stick to do so. (Please have patience with my English, I´m from Sweden". thanks tobbe |
RE: Oilchange gearbox ´98 300tdt
if you will drain from the oil pan, 1 3/4 liter is enough but if you will drain the torque converter (there is a small hex screw), then about 3 liters.
the best way is to measure the oil that you drained and add about a cup. without the chopstick, err... the dipstick, you have no way of knowing it. |
Thank´s a lot for the qiuck answer. What kind of oil should I use then, any ATF-oil or is it neccessary to use "Mercedes"-oil?
tobbe |
ATF oil.
the viscosity are all the same. using MB ATF is good, so you can prevent any shifting problem. i use the same oil on that little green man on the left, and he keeps on running for long now. |
