no start
Old Aug 13, 2007 | 02:40 PM
THESHAKER's Avatar
Default no start
ran out of gas now car wont start 97 e320 put gas directly in intake runs then dies any help would be great
Old Aug 13, 2007 | 05:11 PM
NAZ's Avatar
NAZ
Default RE: no start
can u hear the buzz of the fuel pump when ignition is switch on?
Old Aug 15, 2007 | 01:19 AM
ohlord's Avatar
Banned
Gas into intake tube?It's not a carburetor,doing that to prime the engine can destroy the maf,Air goes in the intake fuel goes out the injectors and only then shall the two meet!!!!as naz said can you hear the f pump?if you just ran out of fuel,make sure you get more than a gallon in to make sure the pickup is submerged,then crank the engine till she starts.but if not started in 10 seconds or so let the starter cool and repeat,no sense burning out a starter ! Some starter fluids are maf safe,however tob be safe you can open the tube at the intake clamp after the maf,spray the fluid start the engine,shut it down and reinstall the tube and clamp,back in action and on down the road again..
ohlord
"GOT CODES?"
be prepared to replace the maf if you poured gas in the intake it went directly on the heated platinum wire and thermister in the maf,that only ever should have air blowing by it.Good luck,KYFC
Old Aug 15, 2007 | 09:58 PM
MBTECHINFO's Avatar
If you want to check fuel pressure, simply remove access the fuel pressure test fitting on the fuel rail. It will have a Brass cap and be a 13-15mm in size(can't remember). Protect your eyes and the surrounding area and press in on the scrader valve to see if fuel pressure is present, have a rag handy to absorb fuel that may be spilt. BE CAREFUL!! Chances are that you burnt out the fuel pump. Recommend always keeping fuel over 1/4 tank to reduce chances of contamination and reduce stress on the fuel pump.
crusier888
Oct 13, 2019 04:46 PM
g-rome
Oct 6, 2012 03:10 PM
doobs
Dec 21, 2008 09:58 AM
jbellia
Jul 16, 2008 08:39 AM
