Need help on 96 E320
Old Sep 29, 2008 | 07:05 AM
mjabrat's Avatar
Default Need help on 96 E320
Changed plugs and wires the other day and atfter testing car out got message regarding check engine. Brought car to autotozone and they ran there diagnostics and came back with faulty egr valve.
My question is where is the egr valve located. ( Any pics wil help ).
Old Sep 30, 2008 | 01:23 PM
bigtire's Avatar
Default RE: Need help on 96 E320
EGR valve is located on the ehaust manifold side of the block toeard the back. It may be that the tube running from the EGR valve and the intake is clogged. This will also trigger that code.
Old Sep 30, 2008 | 02:28 PM
ohlord's Avatar
Banned
Or since you just changed the plugs and wire connectors check that you did not dislodge a vacuum line or any of the lines going to the egr.Or perhaps break an already dried out old one.
ohlord
Old Oct 1, 2008 | 01:28 PM
bigtire's Avatar
ORIGINAL: ohlord
ohlord
Good point, Those vacuum tubes get awfully brittle.
vifa84
Sep 25, 2010 04:26 PM
jvision09
Jul 26, 2008 08:24 PM
benz334
May 31, 2006 11:40 AM
87300eamg
Oct 12, 2005 09:37 AM
smanar
Jul 19, 2003 05:47 PM
