need help with 190e help please
Old Aug 22, 2006 | 12:22 PM
Easy E's Avatar
Default need help with 190e help please
i need to fix the sunroof, when i push the relay no noise no movement i guess i should figure out where the motor is, WHERE IS IT? my stupid a/c doesn't work rightblows half *** warm air and drains gas like i cut a hole in the line(but i didn't), and need to locate and know the name of the center triangle vent plastic peice on the w201 where the sunroof and other two relays go?
Old Aug 23, 2006 | 04:34 AM
Kramerdude's Avatar
Default RE: need help with 190e help please
The sunroof motor is located in your backtrunk at your left side. Remove the plastic-sealing and you will find it.
I experienced the same problem as you describe with the sunroof on my old 190e. But in my case the cablewire that goes from the sunroof-motor where broken.
good luck
MARIODRIVE
Nov 23, 2008 05:39 PM
lubee84
Feb 16, 2008 10:29 AM
sql123
Dec 1, 2007 12:11 AM
ezeneli
Apr 8, 2005 03:05 AM
