Mercedes E320 Stop Light Cover
Does any one know where I can buy the Stop Light Cover? I own an E320 and noticed that the plastic cover of my stop light was broken and is sitting right on the rear counter (rear window area). I think the cover was broken when the mechanic was replacing the stop light bolb. I looked all over the net for the part number and could not locate any online stores. Thee are a few part numbers on the plastic. Any help or tip is appreciated.
RE: Mercedes E320 Stop Light Cover
Does anyone know where I can get a replacement for the Platsic cover for the stop light? I noticed that the plastic cover snaps on the stop light and the snap on is broken. I looked for the part all over the net and had no luck. Any help is appreciated.
get the part number .....
http://www.detali.ru/cat/oem_mb.asp
then plug the # here to order (or any other vendor of your choosing)...
http://www.oempartsdirect.com/
Raymond. I could not get the part number from the first (Russian link) however I found the 10 digit part number from the broken plastic cover and it is 2108200756. I did search through google for the part number but no luck. I also tried the second link you sent and no result either. I will try to inquire through their contact us form but meanwhile if anyone knows of a place that sells this part I would appreciate it. Also any clue what the price for this part would be?
Thanks,
Mishi
Thanks,
Mishi
from older MB parts list.....
21082007565076 3RD STOPLIGHT 4650 3700 2800
retail wholes dealer
in future, it would probably help for you to post information about your car, eg 1999 E320 and if you're in USA or other country.
roger that. this is a fairly low demand part so I suspect the online folks may not likely stock such an item. so only able to get from a dealer rather than a parts broker. so try local junkyard....or ebay also in your search.
sal911
09-19-2010 11:05 AM
charIie
01-03-2006 06:33 PM
