INLET VACUUM PROBLEM
Old Nov 28, 2006 | 01:58 PM
dieselal's Avatar
Default INLET VACUUM PROBLEM
I have a problem with the vacuum on my e220 cdi 2000. I noticed that the small strip underneath the inlet manifold that opens and shuts the butterfly valves via the vacuum assembly has broken one of the connections at the front (number 1 cylinder) I presume. Now I can see that the vave is remaining shut meaning the cylinder in question is running rich and causing the car to lose performance.Is this part of the inlet manifold or can it be repaired without replacing the whole manifold?
Thanks for replies.
Old Nov 30, 2006 | 08:01 AM
dieselal's Avatar
Default RE: INLET VACUUM PROBLEM
Wow! so many replies?
Ok, took off inlet manifold to discover the part had broken off inside the manifold ( had to buy new manifold)
Kevin Rattai
Oct 2, 2013 04:56 PM
buckythetaximan
Aug 1, 2011 07:07 PM
KevinD
May 16, 2011 02:48 PM
Bill Escocia
Jan 30, 2011 01:16 PM
bburn1
Aug 24, 2010 05:42 PM
