Heat stopped working on my E320 (2003)
Old Jan 9, 2008 | 08:05 AM
nlrobert's Avatar
Default Heat stopped working on my E320 (2003)
We were having some issues with the fuel gauge sensor and sent the car in for repair. They replaced the fuel sending units and the associated sending module and that fixed the problem. However, a day after we got the car back the heat stopped working intermittently. Now it seems there's no heat at all. Airflow is fine, but only cold air is blowing out of the vents.
Any suggestions on what to look at first? I'm not sure if this issue is just a coincidence with the recent work or if the recent work may have caused this problem.
Any guesses or typical issues that cause the "loss of heat" problem?
Thanks in advance!
Old Jan 9, 2008 | 11:21 AM
ohlord's Avatar
Banned
Default RE: Heat stopped working on my E320 (2003)
check coolant level.give the duo valves a tap with the handle of a screw driver,they may be stuck.
sometimes a reset of the cars ecu will solve the issue,so if you disconnect the neg terminal and step on the brakes for 30 seconds and rehook the terminal,it may clear the issue.in your manual is the other procedures to do after installing a new battery,which is basically what you tricked the system into thinking you have done.
ohlord
if none of this works you need to make sure the engine coolant is heating up,so after running 15 minutes what does the display read?
Old Jan 11, 2008 | 11:48 AM
97dmsrS420's Avatar
it could be something as simple as the thermostat being stuck open. might want to pressure test.
Old Jan 13, 2008 | 04:52 PM
MBMEX's Avatar
My 2003 E320 stopped heating a couple of weeks ago, AC was fine, but no heat. I just sold the car last week, so I never had the chance to know what was wrong. Good luck.
Old Jan 13, 2008 | 07:22 PM
autoworrks320's Avatar
"so if you disconnect the neg terminal and step on the brakes for 30 seconds and rehook the terminal,it may clear the issue"
What does this procedure do?
Old Jan 14, 2008 | 01:22 AM
ohlord's Avatar
Banned
Resets the cars systems,sometimes it will fix a climate control problem,failure to boot the cd changer,brake light abs warning light faults and a lot of other systems controlled by the controller area network modules and the ecu.Worth a try.Before going further with more tests.
ohlord
Old Mar 1, 2010 | 02:53 AM
mike from tampa's Avatar
did all of the above twice no go; any other suggestions?
Old Mar 1, 2010 | 05:18 AM
mbz connexion's Avatar
My guess would be the heater valve 211 832 05 84 retails for about 37 bucks.
If it's not bad it will be so you're not wasting money by replacing it, even if it doesn't solve your issue.
Old Oct 14, 2025 | 12:43 PM
  #9
dinalatre's Avatar
Interesting!)))
Old Oct 14, 2025 | 12:54 PM
  #10
dinalatre's Avatar
I had a similar issue with my E-Class last winter the heat just stopped working out of nowhere, and I couldn’t figure out what was wrong. After some frustration and a few failed DIY attempts, I reached out for portable heater repair help through heating repair, and honestly, it was the best decision I made. They quickly diagnosed the issue, fixed everything properly, and the heat has been running perfectly ever since. If your car’s heater or even your home system is giving you trouble, I’d definitely suggest contacting them they really know their stuff!
patricknif
Mar 4, 2012 06:38 AM
DonMan
Sep 17, 2009 08:50 PM
PolishPat
Sep 18, 2006 05:41 PM
raspro7
Jan 31, 2005 01:14 PM
e320guy
Jan 13, 2004 04:52 PM
