Fan control switch light
Old Jan 23, 2008 | 04:51 AM
toien's Avatar
Default Fan control switch light
Hi.
I have tried to search the forum for this, but can't find it. The light for the fan switch is broken and I cannot see how to change it. I have a '98 E300TDT with manual A/C.
I have removed the ****, but how to continue? Since English isn't my first language, I am not sure that I have the right name on all components (maybe why I can't find it when i am serching the forum), hopefully you understand what I mean anyway.
Thanks tobbe
Old Jan 23, 2008 | 09:53 AM
97dmsrS420's Avatar
Default RE: Fan control switch light
Go to the "Search" menu via this board, and type in "Bulb Replacement." Perhaps, there are some blogs there that will be of assistance to you. Good luck to you.
Old Jan 24, 2008 | 04:44 PM
E300Denmark's Avatar
Hi Toin, I think I can help you, today I fixed the same problem.
Turn the actual **** horisontally. Then remove it by pulling it out with your nails behind turntable.
You will now see a white round plastic cover, this you gentlyrelease and behind this thesmall bulp is located. Pull it out by using eg. isolation flex or semilar (approx. 4mm).
Hoppas du lyckas med denna beskrivning, du är välkommen att maila till mig i alla fall.
Vänliga hälsningar Peter
seadog
Feb 16, 2011 07:17 PM
fraguada1
May 18, 2009 12:39 PM
brudd
Mar 16, 2007 01:03 AM
QTband
Sep 27, 2006 02:12 PM
alfatodd
Jan 25, 2006 12:29 AM
