Aux. engine fan/ relays/switch?
Old Mar 15, 2007 | 07:17 PM
brudd's Avatar
Default Aux. engine fan/ relays/switch?
My (electric) auxillury engine fans stopped coming on in my c230 2000'. the dealer said there's no temp switch but only two relay's in the engine fuse box. what i wanted to knowwas what sends the signal to the relays to turn on the fans if the relay's aren't the problem? there's a temp sending switch on the engine but does it also feed to the fan relays? the fans are fine. they weren't giving me any answers.thanks jd
Old Mar 15, 2007 | 08:38 PM
chassis221's Avatar
Default RE: Aux. engine fan/ relays/switch?
there is a fan control module on the frame of the car usually on the left side sort of close to the front of the car. a square box that controls the auxillaary fan. its metal and about 4-5 inches by 3-4 inches. they do go bad. also it could be the switches on the a/c reciever/drier that also control the fan.
Old Mar 16, 2007 | 01:03 AM
brudd's Avatar
Thanks, i appreciate the response. i'll check them both. jd
seadog
Feb 16, 2011 07:17 PM
gmen0101
Oct 23, 2006 06:15 PM
haidarsaid
Jan 22, 2005 11:51 PM
Calderon
Jan 18, 2005 06:30 AM
Calderon
Jan 15, 2005 09:44 PM
