Electrical Problems Windows & Sunroof
Old Jan 16, 2007 | 05:06 PM
benzoholic1969's Avatar
Default Electrical Problems Windows & Sunroof
Hello,
1994 E320 coupe
My windows and sunroof work most of the time and then suddenly they just stop. Slam the door, drive down the road a bit, go on in a store come back and then they work, and then they stop...It's totally hap-hazard.
Any ideas? Relay vs Short vs ???
Of note: Even when the switches won't work the key in the door still opens and closes everything.
I've fixed a few electrical gremlins and vacuum problems on him, this is just one more.
Thank you for the help...
Bri
Old Jan 21, 2007 | 05:06 AM
westcoastmercedes's Avatar
Default RE: Electrical Problems Windows & Sunroof
hello, try the simplest things first the fuses are the ceramic ones (blue, red, white ) which over time in use the metallic stip (fuse ) gets cracks in it due to heating up and cooling down check the fuses first in fact best to replace as maintenance i've seen when cracks cause a interruption in power due to driving ,opening a door or just getting hot. and check all the fuse boxes in the car sometimes the description on the fuse car not always indicates other circuits that may be affected
poor01boy-c240
Jun 15, 2009 12:23 AM
alexsouza
Mar 26, 2007 08:28 PM
CollectiveSoul
Feb 18, 2007 03:54 PM
BatonRouge
Jul 3, 2005 12:55 PM
