E430 Key Issues
Old Oct 12, 2021 | 11:26 AM
75Stutz's Avatar
Default E430 Key Issues
I have a 99 Meecedes E430 with frustrating ignition key issues. I have gotten a new key because I lost the original. . I actually removed the ignition switch (EIS) and sent it to a "Mercedes locksmith" to get a replacement key programmed to match the EIS. I installed the EIS and the key worked d perfectly for about a week. Then, it wouldn't turn again, even to the extent that it does not lock and unlock the steering wheel or doors . The key will not turn at all!!! I suspect at this point, that the problem is now mechanical, and that the tumbler assemble inside the ignition switch is the culprit.
in frustration, I have ordered a used EIS with matched key from a Mercedes parts specialist.. it is actually from a 2001 C320, but "GUARANTEED" to be a compatible exchange. I am hoping it would be a simple remove and replace operation. My concern is not b ING on these cars is simple!!
Would any of you know if this should work without further programibg????
Thanks,
John
Old Apr 21, 2023 | 04:50 AM
MattsMerc's Avatar
Hey John,
I'm looking at doing the same with a 1997 model
did yours work?
Thanks,
Matt
rmp141
Sep 20, 2011 03:31 PM
Phillybenz club
Aug 8, 2010 04:48 AM
richardt
Jan 22, 2007 07:23 PM
richardt
Jan 12, 2007 10:27 PM
mbclassicguy
Dec 20, 2005 11:50 PM
