e320 model 1995, automatic
Old Jul 22, 2006 | 03:18 AM
Qamar's Avatar
Default e320 model 1995, automatic
Well guys i have the subject wagon. I am not getting my 5th gear at all. Maybe this model came with this problem. I have driven four gear tranmission in my previous Merc, never had any problem in that.
My Mechanic had checked all the electronic circuts but could not trace the fault. I am now moving in 4 years. Otherwise the gear shifting from 1st to 4 th is ok. Now there is no Od (5th gear)
I have changed the tranny oil with the new filter but there is no improvement in getting the 5th gear on.
Anyone can tell what could be the problem
Old Jul 27, 2006 | 07:19 PM
jmang09's Avatar
Default RE: e320 model 1995, automatic
sleepwalker might know this...
Old Jul 27, 2006 | 11:26 PM
Laterthatsameday's Avatar
1995 124 wagon had 4 speed automatic, non electronic transmission in the U.S. We didn't see a 5 speed until '96, and then it was only on the V8 cars. In '97 all autos were 5 speed electronic.
Old Jul 30, 2006 | 07:20 AM
Qamar's Avatar
It's the 722,5 and the transmission is vaccum controled but the fifth gear is a electronic switch you press the stick left and the switch put the transmission out of the 5 gear only shift in 4th gear.
Well thanks God my 5th gear problem is solved finally. Well the mechanic concerened who is also a good electrician traced the fault. Nothing was coming on the computer check, i mean any fault. So he started checking all the points like Relay No 9, then the switch which is attached with the gear shifter lever which from the "D" drive can be shifted for manual, and the last connection of the switch which goes in the transmission oil pan through the switch mentioned above.
He lifted the rear left wheel of the car with a jack and then two guys sat in the car one on the driving seat and the other on the passenger side. The guy who was on the driving seat was responsible for ecclerating the engine (Spellings) uptill 100 KM. The other one from the passenger side had opened the gear shifter campartment and had given direct jump with a wire (From The shifting Switch) At once the car after getting the speed of 110 Km went into the fifth gear. So he took one new swith from the market and the problem is solved
The moment the fifth gear started working it gave a new life to the car engine. The downshifting started automatically. So it is proved that when the 5th gear in my car make and model is not working the car starts moving at a snail speed and there is no downshifting of gears also
Hope this might help for those who are moving with this problem
Cheers
rohitsagar
Apr 14, 2007 02:17 AM
Qamar
Aug 20, 2006 06:06 PM
qghauri
Jul 7, 2006 05:20 PM
qghauri
Mar 13, 2006 04:58 PM
qghauri
Dec 2, 2005 07:37 AM
