E320 CDI auto gearbox won't change gears? Can anyone please advise?
Hi There, I am a new member and desperately need some advise.
I have a 2001 E320 CDI turbo diesel automatic tiptronic but my merc won't change gears, it stays on 1st gear all the time, i don't think it can be the gearbox itself as it is not slipping and I am not hearing any rattling or broken bits coming from the gearbox so I was wondering if it could be the ECU or does the car have any other gearbox sensors which tells it to change gears?
At first when it wouldn't change gears if I switched the car off and then on again it would work fine but now it just won't change at all and even the manual gear change won't work either.
Could it be the ECU or any sensors?
Would be very grateful for any advise.
Did you spill any fluid into the gear selector?
Try resetting the system,unhook the neg battery cable and with the key out of the ignition step on the brake pedal for 30 seconds,rehook up the battery cable.Follow the reset procedure outlined in the manual for how to sync everything after battery change.
may help if it is a computer gremlin,if not you will need a shop to read the trans codes.
ohlord
ohlord
Thank you oh Lord for your help and advise.
There hasn't been any spillage of fluids in or near the gearbox selector.
I tried your suggestion of disconnecting the negative cable on the battery and depressing the brake cable but unfortunately it made no difference and the car still wo'nt change gears. It sounds like it's in Limp mode.
Any other suggestions what it could be please?
Regards
Tony
Regards
Tony
i'm new here, and sorry for my poor english as i'm from Portugal,
I have a e320 from 2002, auto box, and in my case I start having troubles when I stop for a wille like in one semaphore, and when I need to proceed the gear box don't respond, it stay like in 2º all the time. In the past I stop the car and when I start again the problem was solved. But today when I start in the morning it was ocurred and now the mecanic whant me to bay one new gear box, Can you help me to clarify this, please,
Thanks.
Eduardo Vale
Thanks.
Eduardo Vale
dinesh.panchani
Apr 10, 2013 07:40 AM
gadget153
Jan 24, 2009 07:53 AM
