e300 will not start
Old May 2, 2009 | 09:51 AM
mahoskic's Avatar
Question e300 will not start
My 1996 e300 died the other day and it seemed like it was out of fuel. I added fuel and check the strainer and it was dry. after about 5 min it filled up but the car will not start.
i turned the motor over with the strainer out and i did not see any fuel flowing out of it. i blew back into the tank and that started the fuel to fill the strainer and flow out of the strainer cap.
checked the glow plugs and they seemed ok 9 to 10 ohms.
My old 300d i could just pull and it would start @ 20 mph.
Any Ideas?
Old May 2, 2009 | 11:13 AM
mbenz80's Avatar
I believe you have to post your question in diesel forum section. You should check o-rings on fuel supply lines going into fuel pump, you may be sucking air in that place. Keep trying starting it few times, it will take a while to replace all traped air with diesel fuel. Is glow plug light coming on and off as it should?
Old May 2, 2009 | 06:38 PM
mahoskic's Avatar
Thanks it is looking like the o rings, after cranking the car for a while I pulled the strainer and there were all air bubbles in the reservoir.
now where do i get them?
Old May 3, 2009 | 12:20 PM
iluvjesus's Avatar
You need to change all the fuel lines too, it is a simple DIY.
Old May 13, 2009 | 09:42 PM
mahoskic's Avatar
Changed all the fuel lines but still no fuel.
time to change the pump?
Old May 13, 2009 | 10:01 PM
mahoskic's Avatar
What type of fuel flow should i expect from the pump?
i was told to replace the injector asm a bit expensive and never known one to go bad.
the fuel pump is much cheaper.
has anybod had teh fuel pump go bad?
Old May 14, 2009 | 05:56 PM
mahoskic's Avatar
changed all the lines and now that i can see the fuel in the lines i noticed that i can get the fule to fill the lines but when i go to start the car i noticed that the fuel flows backwards from what the documentation shows.
now what?
Preben
Aug 10, 2013 09:01 AM
BritChris
Jul 23, 2013 01:23 PM
BritChris
Jun 24, 2010 09:24 AM
mahoskic
May 16, 2009 02:20 PM
zafar320
Aug 10, 2007 02:20 PM
