Duovalve not the A/C problem. 1997 E420
Old Aug 19, 2009 | 06:10 PM
kimster's Avatar
Default Duovalve not the A/C problem. 1997 E420
A/C blowing 58 F passenger side, 82 F drivers side, ambient 92. I followed the posts and did the pop rivet repair, (EXCELLENT), however still hot on drivers side, opened up the duovalve again and everything's OK.
The d/v top forward outlet seems to be the supply coolant line to the valve, as I dis-connected it, started the engine and got coolant flow toward the d/v.
Put a shut off valve in the coolant line to the top forward facing oulet on the dv, ..........still hot drivers side.
I know there are left and right heaters that bleed the coolant into them for climate control, are there two A/C evaporators, left and right?
If there are two evaps, any ideas what the problem might be. I've ran the full A/C diagnostics with only 232, 234 and 235 codes, 417 and 418 did not register.
Any suggestions will be appreciated.
Old Aug 20, 2009 | 06:53 PM
chassis221's Avatar
usually its just a low freon charge that causes that.
ulremember
Jun 5, 2010 03:15 PM
randazzop
Aug 2, 2006 01:54 AM
overrev
Oct 23, 2003 10:24 AM
BMurphy
Oct 10, 2003 06:32 PM
edmond03
Jul 24, 2003 05:51 AM
