Down shifting...is it an alternative?
Old Mar 16, 2009 | 04:50 PM
jkoch's Avatar
Default Down shifting...is it an alternative?
I have been down shifting and finally using my breakes as necessary as I approach a stop at a light, stop sign, etc.. The idea is to save wear on my breakes...and add a little action to my driving.
Question is, am I saving breakes and wearing out my transmission?
Old Mar 16, 2009 | 05:17 PM
MASKA's Avatar
Default brakes vs trans
Which is the Cheapest To Replace !!
Old Mar 16, 2009 | 08:57 PM
sgilman's Avatar
I don't know that regular downshifts will cause noticeable wear on the transmission but considering the relatively low cost of replacing pads it doesn't seem like it's really worth it.
Old Mar 17, 2009 | 05:32 PM
MASKA's Avatar
Cool brakes vs trans
Enough said ; I think he's got the picture !
Old Apr 5, 2009 | 05:00 PM
jkoch's Avatar
Originally Posted by ForcedInduction
Which option is better?
A: 30 minutes and $75 to replace a set of brake pads
B: Several hours and $2000+ to rebuild a transmission.
I respect your opionon, but where do I get a $75 brake job on a Mercedes?
Old Apr 18, 2009 | 10:04 PM
Brokendriveshaft's Avatar
Is the transmission a manual? Because if you're down-shifting an automatic, yes that is going to cause excessive wear (mainly because you're down shifting the transmission with higher than normal load, the load of your entire car with momentum, it tends to wear the clutch packs out and cause excessive chattering in the planetary gears if done regularly). It would probably be equivalent to up-shifting under full throttle with 800hp. If it's a manual, then engine braking is perfectly normal and safe on your transmission. As long as you are rev matching before you down-shift, then you are doing no more damage to your clutch and transmission then a normal 2nd to 3rd shift. If you are just slipping the clutch or dropping the gear hard, then you are causing excessive wear on the clutch or transmission.
Sin City
Jan 8, 2009 01:33 AM
LORE BENZ
Dec 15, 2007 11:25 PM
LORE BENZ
Dec 10, 2007 03:05 PM
bevibrant2
Nov 13, 2007 09:46 AM
phlrnlds
Apr 18, 2004 05:35 PM
