Disable Traction Control
Old Nov 15, 2006 | 02:47 PM
sandip215's Avatar
Default Disable Traction Control
I work in a chassis dyno facility. We have a 2006 E320 and can't run it on the dyno since the traction control kicks in (limits speed) when the front wheels aren't turning. Does anyone have a procedure to shut off the traction control.
Old Nov 15, 2006 | 04:04 PM
snanceki's Avatar
Default RE: Disable Traction Control
Surely you have this problem with lot of Traction Controlled vehicles?
Likewise what do you do with 4matic?
Stuart
Old Nov 15, 2006 | 05:48 PM
sandip215's Avatar
For most of our test vehicles we can interface with the vehicle computer and disable the features.
As an update, I found a method used on other mercedes models. It worked on ours too.
Put the ket in position 1.
Immediately hit the odo reset button three times.
The console will flash and change to a battery voltage reading.
Use the arrows on the steering wheel to scroll through options.
When you get to ESP/ABS... hit the plus sign to disable.
Now start the vehicle.
NOTE OF CAUTION
On the other models they say it resets when you remove the key and restart.
That is NOT the case with this one. You have to reenable it through the menu.
BE SURE to check this before taking the vehicle out on the road.
Old Nov 15, 2006 | 06:06 PM
snanceki's Avatar
I suspect this procedure will only work on the most recent MB models.
However I will try in the morning on my 2000 S Class.
Glad you got it sorted.
Stuart
volvolus
Jan 18, 2006 04:45 PM
mharnouski
Jun 19, 2005 08:45 AM
chairman4u
May 1, 2005 07:35 PM
McMucker
Mar 2, 2005 11:20 AM
stimike
Nov 27, 2004 07:58 AM
