Cleaned TCU...now stuck in 1st? any suggestions?
Old Aug 28, 2005 | 02:52 AM
  #11
gqgifts's Avatar
Default RE: Cleaned TCU...now stuck in 1st? any suggestions?
Gotcha. I appreciate all the help and advice!
Old Aug 28, 2005 | 02:38 PM
  #12
gqgifts's Avatar
This morning, the "check engine electronics" light came on immediately. I'll take it to the dealer tomorrow and see what happens.
Old Aug 28, 2005 | 06:28 PM
  #13
gqgifts's Avatar
Ok...NOW, the battery seems drained. I think it might be getting overcharged and boiling over because there is a puddle of water around the battery. Do you think all of these problems are related? This is the first time this has happened.
Old Aug 29, 2005 | 12:40 AM
  #14
sleepwalker's Avatar
the battery and charging system could be a different problem.
there is a voltage regulator inside the alternator to control the charging. if this regulator or the diode/s is faulty... then problem happens.
your battery is new? (less than 1 year)???
Old Aug 29, 2005 | 04:36 AM
  #15
gqgifts's Avatar
Actually, I just bought the battery last week. I didnt have any problems with the old one, but I was planning a long roadtrip and wanted to replace it.
Old Aug 29, 2005 | 11:42 PM
  #16
gqgifts's Avatar
Well, it looks like the battery was defective. I replaced it and the power problem has gone away. I had the car scanned and about 12 errors showed...mainly transmission errors. The codes were cleared and the car is still in emergency mode. I guess its time to order a new TCU.
Old Aug 30, 2005 | 12:06 AM
  #17
yep. seems cleaning it doesn't correct the problem anymore.
remember that the part number should match with the electrohydraulic valve body.
Old Aug 30, 2005 | 12:32 AM
  #18
gqgifts's Avatar
Right. Do you know if its still possible to get the 017 545 05 32 ECM so i would not have to get a new valve body also? Or do i have to get a 017 545 06 32 ECM and matching valve body?
Old Sep 1, 2005 | 04:58 AM
  #19
gqgifts's Avatar
Well, the transmission has not been fixed yet. I ordered a new TCU/ECM and valve body but they have not arrived yet. Once i try those Ill update the forum.
Old Sep 1, 2005 | 05:06 AM
  #20
i will need your VIN if you want to know about the right parts.
anyway, you must match that valve body and ETC so you won't have the 3 seconds engagement delay (from P to D).
shy_diddy
Aug 28, 2011 08:20 PM
ivokpetkov
Aug 27, 2010 03:47 PM
GreenzzAMG
Sep 25, 2008 03:06 PM
barker30040
Jul 13, 2007 12:21 AM
xjvoorheesx
Jul 29, 2006 01:21 PM
