central locking
Old Aug 21, 2004 | 03:28 PM
HardeepG's Avatar
Default central locking
Hi, got a problem with my 98R E200 avantgarde i've just bought.
The locking wont work, just the lights flash, indicators work when they want to, and whenever the indicators stop working so do the electric windows.
Also i was told there was a problem with the electric sunroof in that it cannot be retracted as the guide for the steel wires have worn loose. I have been advised that i need a complete sunroof magazine, is this true, or can i just replace the guides??
Any ideas on how to fix any of these problems
Thanks for any help
Old Aug 21, 2004 | 10:13 PM
sleepwalker's Avatar
Default RE: central locking
PSE (pneumatic system equipment) pump faulty brush on motor.
steel wire on guide tube? did they open and check it? i doubt that.
Old Aug 22, 2004 | 01:37 PM
HardeepG's Avatar
Right, i'm on the hunt for a new PSE pump, thanks.
On the sunrrof, it was opened up and checked. I'm told its a problem with w210's made around 97/98, along with rusting around the bottom of wheel arches and doors.
If i do get a new magazine, can i buy without the glass, as my glass is in perfect condition
Thanks all
Old Aug 22, 2004 | 08:17 PM
of course. the glass is a separate component.
you better spray an undercoat inside the running board too. the water accumulates there during rainy days. there are two rubber grommet where you can insert noozle. a can is enough together with the wheel arch. use the rubberized type undercoat.
delboy277
May 12, 2009 05:19 AM
kjr
Oct 29, 2004 07:03 PM
fwillie
Oct 8, 2004 01:24 PM
mstanglin
Sep 20, 2004 03:30 AM
forfar4
Jul 4, 2004 02:42 PM
