Wiring and/or Central Locking Help Needed
Old Sep 9, 2004 | 01:54 AM
mstanglin's Avatar
Default Wiring and/or Central Locking Help Needed
Does anyone have a wiring diagam for the 8 pin connector that goes to the overhead dome light for a 94 S500 Coupe? I took the cap off and several of the pins jumped out...need to determine which color wire goes where. THEN, by eliminating that, I can continue with more confidence on the primary problem I am having with the central locking system. I have read all of the threads, have tried everything including buying a new vacuum pump...the one that goes in the trunk left. Don't laugh, but while working on it I discovered that turning he key in the driver side door caused the window on the passenger side to go up and down depending of which way the key was turned. It is no longer doing this (for now) which leads me to the believe the prob is no doubt in the wiring somewhere. There is power going to the new vacuum pump and it does come on. Anyone have any thoughts? Thanks!!!
Old Sep 11, 2004 | 10:40 AM
sleepwalker's Avatar
Default RE: Wiring and/or Central Locking Help Needed
your VIN or Chassis number?
you need to initialise the power windows to make it work.
Old Sep 18, 2004 | 03:31 AM
mstanglin's Avatar
VIN #WDBGA70E7RA172967. Do not know what is involved with intializing power windows...searched for threads...can you help. What are your thoughts about the dome light wiring? Wire color codes available. Thanks in advance...!!
Old Sep 20, 2004 | 03:30 AM
e15 is the dome lamp.
i think you only need the wire color according to pin number.
[IMG]local://upfiles/1/38D79B6B208A43EB8F0F3EAC95B65CE4.jpg[/IMG]
stuart2106
Feb 28, 2010 10:39 AM
delboy277
May 12, 2009 05:19 AM
Josh Flynn
Dec 15, 2008 06:59 PM
wpimetnel
Oct 19, 2007 02:44 PM
merc500
Sep 18, 2007 08:15 PM
